Omega oven model number is OO910XA
If it is a common problem with Omega, they may not be ready to admit it. Since it occured 2 times, possibly the hinges use nylon rollers for smooth and quiet operation, but the hinges are not well shielded from the hi heat of 500-600 degrees and the nylon parts fail after a few months constant heat exposure. There is a common problem that happens with oven doors when they do not seam to close tight: besides being old and normally worn, if a door is leaned on while it is open, the hinges could be stretched and then they will never allow the door to close tight. This has happened to many ovens regardless of age, and the customer never realized that the weight or pressure they applied to the door when in the open position has done damage; yet they wunder why the door does not close well. Goodluck,Macgivor
