In general, you have to order recovery disks from the manufacturer of the machine.
In your case eMachines Store eRecovery is where you can order it, or you can initiate a discussion with tech support.
Also, many machines give you the option to burn your own recovery media when you first set it up. Most people skip this step. You should do this before you have problems. Search your machine for the word Recovery and see if you have an installer routine there.
Here are instructions to create a recovery disk on a USB stick
Create USB recovery drive Windows Help
SOURCE: Emachine w3650 recovery disks....
One option is to run virus removal software in windows safe mode which is started by pressing the F8 key when starting up the computer. I suggest running an online scan such as trend micro housecall at housecall.trendmicro.com/ . This will probably remove the virus. Also, is there important data on the hard drive that she will need? If that is the issue, there are other ways to copy files from the hard drive without actually copying the virus. Let me know exactly what you want to do? If you just want to run the recovery, but lose everything that was on the hard drive, use the F11 and it will completely refresh your computer to how it was when you got it. The discs aren't necessary as the recovery section is on the Hard Drive.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
