Question about Fossil Philippe Starck PH1035 Wrist Watch
Fossil watch rubber straps PH 1035 - Fossil Philippe Starck PH1035 Wrist Watch
Anonymous
SOURCE:
Anonymous
SOURCE: How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
Posted on Aug 09, 2008
diarmaidok
  • 4 Answers
SOURCE: philippe starck with fossil ph-2006
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Posted on Dec 02, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
Posted on Dec 19, 2008
Anonymous
  • 373 Answers
SOURCE: Replacement battery for Philippe Starck Fossil watch
can you check on web site
Posted on Jan 31, 2009
Anonymous
SOURCE: I need a replacement strap for Fossil watch
I've been looking all over my area for an FS3041 strap too. Even the jewelry shop that has Fossils only carries crappy bands that won't do the watch face any justice. And fossil.com doesn't carry bands for past models, which this is. I may have to make one from an old shoe. :)
Posted on Jan 26, 2010
How to set date on xhilaration
Google (fossil)(model)(manual) without parens for instructions.
Jun 20, 2014 | Fossil Xhilaration White Rubber Bumpy...
I need to replace fossil FS 4210 Strap for new one, old strap was broke.
At TicTacArea.com you can find almost any Fossil strap you may need.
If you can not find it online, ask our team , sure they will help you out. Straps for Fossil Watches
Jul 20, 2011 | Fossil Strap Chronograph Gunmetal Dial...
Hi there I'm desperately looking for a replacement black rubber strap for my Fossil/Starck O Ring watch. Please let me know if you have any advice for me. thx Greg
Go to their web site "fossil.com" and at the bottom of the page there is a menu.
Click on "customer care" and you will see another page with a menu on the left.
Click on "order links and bands" and follow instructions.
May 24, 2011 | Fossil Watch PH1085
Does Fossil sell a replacement strap for this watches?
Yes, you can get straps from Fossil.
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html and click on the heading "ordering links and bands" in the menu on the left.
Jan 07, 2011 | Fossil Strap Watch for Women
New rubber strap required
At a watch store or Jewelry counter in most department stores.
Jun 30, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
I need a new wristband for my ph 1035 watch. How can i get that - is it possible?
Yes it is posible.
Go to "www.fossil.com/en_US/shop/customer_care/static/fossil-orderlinks.html" where you will see "ordering links and bands".
Mar 13, 2010 | Fossil Philippe Starck PH1034 Wrist Watch
Dec 19, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
Dec 16, 2008 | Fossil Watches
Fossil Philippe Starck PH1035 Wrist Watch Logo
97 people viewed this question
Top Fossil Watches Experts
Janelle Schoonover
Janelle Schoonover
Ray Murphy
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
