? 1:31
https://www.youtube.com/watch?v=GFw2j6ufTH8
May 28, 2013 - Uploaded by Pop Acap
This 2005 VW Jetta SE was involved in a motor Vehicle Accident and ... I had troubles with my vauxhall zafira 1 ...
Aug 10, 2006 - i was driving into my apartment complex, and i put my car in park ... He checked the shift lock, fuses, brake light switch, computer stuff ... Automatic ShifterStuck in Park, waldo358, Volkswagen Passat, 1, 12-27-2007 05:23 PM.
Locate where the shift cable linkage mount to trans, check for good tight attachment to ball socket, then have some one move shift lever through gears watch to see if cable moves shift arm BOTH directions if not replace cable
safety switch on brake pedal. common cause is a wire breaking off. there are 1 to 2 wires going to this switch. It is located on the brake pedal bracket above the foot pad.
you might have bad ground to transmision that happen to my 01 jetta were it would just kind of rmp no shifting gears dealer said it was bad ground to trany
VW Automatic transmissions must be filled within a specific level or they will not shift. Also, must have VW special transmission fluid or ATF +4 FULL SYNTHETIC!!! Required to create proper internal pressure...
