What could cause the engine to idle fine when starting but upon acceleration it kills and wont idle again. Only continues to run by pumping accelerator and jerks and kills. What could cause this ? Poss. Relay, Fuse or could it be the pump> It is a 99 dodge Ram Sport 5.2 Lt. and has computer chip I believe?
SOURCE: cant get choke to operate on C50TLRY 2000 50 hp 2
Check choke itself to make sure it moves freely. Adjust the cable and spring if necessary. If the choke is controlled by a vacuum controlled actuator, make sure it is not leaking or loose pressure
SOURCE: I'm trying to wire a 12v bilge manual pump to a
You run your hot wire to the switch (brown) and black wire to the pump (+ve connection). Then from the pump run another wire to the negative terminal of your battery. I used to use a toggle switch on mine, but I do not use a starter motor, still all the lights, radio and echo sounder are connected to it (via a junction box). The only item I fuse is my echo sounder.
SOURCE: 1987 Bayliner capri 85hp force starts and idles fine,after it
if u have a seperate onboard tank i bet its the vent valve is closed
You could have a sort circuit, somewhere
