Question about Casio EXILIM EX-Z1000 Digital Camera
'ok' button wont work. no response. cant delete pics or format. also, zooms in and out by its-self
  • 44 Answers
Sounds like you have a sticky button issue. maybe someone touched the buttons with something on their fingers or splashed a bit of softdrink (soda) on there. your best bet would be to get it in for a sservice and get it cleaned.
Posted on Jun 28, 2009
6ya staff
SOURCE:
Camera says "card not initialized" and won't operate...help!
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure.In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
May 20, 2010 | Fuji FinePix 2800 Zoom Digital Camera
Zoom, Menu/OK, up, left,right all don't work but
Try moving down, and then moving up. Similarly, try moving the opposing directions for left and right. If there is no way to go in a certain direction, on a certain screen, it will appear that the button isn't working. I think you can solve it now. I have faith in you.
Apr 22, 2010 | Fuji FinePix F460 Digital Camera
Rca 62 inch projection the screen is a little wider.cant see some things on botton and sides
Sounds as though you have the set in zoom format. Check your remote for a screen format button and switch it to wide or normal format. This button may also be labeled as "Aspect" for aspect ratio which is the ratio of of width to height. Older sets had a ratio of 4:3 and the new wide screen sets are 16:9. In zoom format the pic. is expanded and pushes some of the pic. off the screen display area.
Nov 10, 2009 | RCA Televison & Video
Removal of write protection
Sounds like you will need to format the internal memory of the camera. This will permanently erase all the data from the memory and then you will be able to use it again. To format the memory: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the memory can be used again.
Mar 22, 2009 | Olympus Camedia C-480 Zoom Digital Camera
Mar 22, 2009 | Olympus FE-320 Digital Camera
Deleting pics
When in the playback menu, toggle the zoom out, as if you had already zoomed in on an object and then wanted to zoom back out. This should cause the pictures on your camera to be displayed in thumbnail mode. When you hit the trash/delete button in this viewing mode, you will be given the option to delete the entire folder's contents. You can also highlight a selection of thumbnails, then delete them all at once by choosing the "Select" option.
Nov 17, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
When i turn myolympus d-545 zoom on it reads card full. Then when i try and look at the pics to delet some nothing happens.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card full message and the card can be used again.
Aug 12, 2008 | Olympus Cameras
Card not initialized
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
Feb 26, 2008 | Fuji FinePix 30i Digital Camera
Deleting Pics.
IF YOU HAVE A MEMORY CARD, YOU CAN DELETE IT THROUGH YOUR COMPUTER OR YOU CAN CONNECT YOUR CAMERA TO THE COMPUTER AND DELETE THEM FROM THERE.
Feb 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Pic. delete
put the camera in PLAY mode. Press the W button (zoom) at the top right of the camera. You should see a bunch of pics on the screen. Press the delete button. Select "DELETE ALL IN THIS FOLDER". Select OK.
Oct 27, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Casio EXILIM EX-Z1000 Digital Camera Logo
71 people viewed this question
Top Casio Cameras Experts
Ekse
Parshiv Luthra
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
