Question about DeLonghi DE500P Dehumidifier
How do the hoses go back on the de500p - DeLonghi DE500P Dehumidifier
What diameter tubing is used with the Delonghi DE 500P pump
George, regular garden hose is what is generally used for continual drainage. Just don't exceed the maximum length of hose, that is listed in your Owners Manual.And, despite what they say about being able to pump water up thru abasement window, it really doesn't work that well. Unless the unit is right below the window,
Hope this helps you and thanks for choosing FixYa.
Sep 04, 2011 | DeLonghi DE500P Dehumidifier
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
When tank is full, it doesn't shut off, and tank overflows
yes jenn when the tank fills it will shut off so that it dosent run all over the floor on many models you can hook a hose on to the tank and find a place to drain itto like a floor drain etc
Apr 09, 2010 | DeLonghi DE500P Dehumidifier
My 3-month old Delonghi 50 dehumidifier is leaking
Did you find the solution to your delonghi 50 pint issue? We have similar problem and No Manual - we are looking for manual too, any thoughts on where to find that too, please?
Jul 06, 2009 | DeLonghi DE500P Dehumidifier
Need a part
This appliance has 3-ft drainage hose and a 16-ft pump hose. I searched for a store that carry these hose, unfortunately, none of them sell a part or accessory for the DE500P.
Kindly click this link and verify if they could sell a hose:
http://www.nextag.com/delonghi-de500p/compare-html
Good luck.
May 03, 2009 | DeLonghi DE500P Dehumidifier
DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
Mar 24, 2009 | DeLonghi DE500P Dehumidifier
Problem
Is your pump hose connected tightly?
Jul 20, 2008 | DeLonghi DE500P Dehumidifier
De500p lost owners book
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
This should solve your problem.
May 05, 2008 | DeLonghi DE500P Dehumidifier
DeLonghi DE500P Dehumidifier Logo
100 people viewed this question
Top DeLonghi Dehumidifiers Experts
nm156
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
