You can either use the units own spark plug as a visual tester or get an inline tester from a parts store. Most of the time just using the unit spark plug is enough. As long as you can see the head of the plug while it is resting on a metal part of the engine for grounding purposes. They make 20000 volts so it should jump a good sized spark plug gap no problems.
Be safe and good luck!
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
SOURCE: No Spark, plug is good
Hi
If you have a good plug in still no spark you will need to install a new coil.
Sam
