No router! I can't find other networks, even they are '' avilable '' about 10 more.... ?
What i would suggest is get another wifi receiver dongle if that one fails its probably your laptop needs repairing if you have a friend that has one you can borrow from or you can get them cheap on ebay i had the same problem with a laptop and i just plugged in a dongle i got on ebay and it worked it doesn't have to be a lynskys it can be any wifi dongle receiver if tht fails your router might be damaged your ISP provider may be able to help you determine the problem for free they can run tests with you over the phone too see if the signal is reaching the router or maybe you could try hard wiring the laptop to router with an ethernet cable see if that picks it up if tht does its either the router or dongle or you might have broken the wifi built into your laptop... Hope some of this helps..Sean
