speed class choices.
about compatibility with host devices
before choosing your card, it is important that you understand how to use your memory card to it greatest ability. sdxc memory cards and devices (digital cameras, video cameras, laptops, etc.) are now available. learn how to use your new sdxc memory card to optimize its performance.
confirm compatibility
before inserting your sdxc memory card, confirm the device is compatible with the sdxc standard by locating an sdxc logo on the device or referring to the device's user manual or manufacturer information.
understanding backwards compatibility
sdxc memory cards must only be used with sdxc devices.
sdxc devices can use sd memory cards, sdhc memory cards and sdxc memory cards.
sdhc memory cards can be used with sdhc devices and sdxc devices.
sdhc devices can use both sd memory cards and sdhc memory cards.
The S1 uses SD cards. SD cards top out at 2GB, any larger cards are actually SDHC (Secure Digital High Capacity). SDHC devices will accept SD cards, but SD devices will not accept SDHC cards. They will fit physically but not electronically.
In fact, the S1 manual does not list any cards larger than 1GB.
The "E30" error code indicates reading/writing data on a SD card has failed.
Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data.
Solution
To clear the "E30" error, try performing the following procedure.
1. Try using another SD card.
If you have another SD card, try loading it in the camera.
If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera.
2. Use your computer's ScanDisk utility to check the SD card for errors.
Use ScanDisk to check the SD card for card error or card failure.
Refer to the instruction manual for your operating system or Windows Help for further instructions.
(If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.)
Be sure to back up the data on the SD card on the computer before you check the SD card.
If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card.
Follow ScanDisk's on-screen instructions to solve the problem.
3. Format the SD card with your camera
Try to format the SD card with your camera.
Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card.
Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors.
If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Solution
Solution
Solution
Solution
