Small white gears [L/H & R/H] on chromed bar across top of carousel has 1/2 tooth's.
********* gear on Carousel has 1/2 tooth.
These are the index marks/position @ yellow or black [however you look at it].
Get it wrong and all cartridge warning lights flash together.
Set gear behind frame [motors' side] 180 degrees from current position [also 1/2-"toothed"] if latter happens.
This printer has no carousel alignment. The toners do not fit into a carousel. This printer has an imaging drum and print cartridges black, cyan. yellow and magenta. Please be more specific about what you are trying to do or what the printer is doing or not doing.
what country are you from that they dont fit into a carousel
you know the thing that spins the toner forward for you to change each color ?
