SOURCE: Hi,on my Samsung microwave over
the wiring to the oven light,or light swicth is shorting out.will likely have to have a repairman service it unless you know some one with some elect.experiance
SOURCE: Samsung microwave door popped open and now won't
The spring attachment to the moving latch has broken off either replace the latch or drill a small hole in the latch body and attach some heavy steel wire to make a new attach point for the spring. the inside trim easily pops off and the latch just slides off.
SOURCE: microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
SOURCE: Samsung smh9187w microwave oven door will not close
The hinge latch hooks are flimsy on many of these but almost any shop can repair this issue--unit has to be taken apart.
SOURCE: samsung microwave ovens model mo1650ca turntable stopped turning
Are the internal cooling fan and stirrer (in the ceiling of the oven) running when you cook?
The turntable gets its 21VAC power from a tap on the cooling fan motor, and it's controlled by a relay on the circuit board.
So it's important to know if those other two motors are running, too.
You will have to temporarily remove the stirrer cover from the ceiling to see if the stirrer is turning when you cook.
For some weird reason, this model's service manual is not in all one piece. So
you have to download all the sections separately:
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.01.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.02.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.04.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.05.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.06.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.07.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.09.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.10.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.14.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.16.pdf
You can find handy exploded views and order parts by model number here.
If you need circuit board repair, we do that for $39.95 in most cases.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
