SOURCE: bad smell in drum of washer
Unfortunately this is a quite general problem today as we are washing more and more in rather low temperatures. Gunk and slime packs up in the rubber gaskets and elsewhere in the machine, smells horrible if not kept under control.
There are a few things you can do.
1) The most important thing IMO is to make sure to wash at the highest temp at least once a week, 90-95 degrees Celcius.
2) Always leave the washing machine lid half open when not in use in order to allow the inside to dry.
3) A supplementary thing is to run an empty machine wash cycle once a month or so using bleach (chlorine) in the recommended dose for your machine. Use highest temp to maximize effect.
There is also some work that can be done with a rag, mechanically cleaning out the gasket and all accessible parts in the detergent compartment etc, however this may have quite limited effect. Worth trying nevertheless.
Other than that you c
SOURCE: my washing machine has a bad smell and wont work
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
