Question about Thomson Lands Phones
The phone makes no sound and doesn't get any calls when people call but the volume is all the way up. The whole phone system works but that issue. It is a model 28821FE2-A. What do I do?
It is a DECT 6.0 based phone. I can't hear anything even when the volume is all the way up and it is not on mute. When people call it goes straight to "The person you have dialed is not answering. Please leave a message after the tone." Even when someone leaves a message it won't come through. The "do not disturb" is not on.
Anonymous
SOURCE:
amy817
SOURCE: mute is turned on cannot hear phone ring
I can't talk or hear outta my phone. I can dial people but i cant hear them and they cant hear. My phone model Cordless 5.8GHz Edge Dual Handset Phone System with Caller ID:
Posted on Jun 13, 2008
Anonymous
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
Mark Egan
  • 1214 Answers
SOURCE: FLASHING BASE 1 - PHONE'S LOCKED
Unplug the batteries for 30-45 seconds. Reinstall, and attempt to re-register the handsets to the base.
Posted on Jan 26, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: The answering machine announcement on
Go to the link below. On page 36 and 37 tells you how to set up the answering machine.
http://www.p4c.philips.com/files/c/cd2452b_05/cd2452b_05_dfu_eng.pdf
Good luck please rate 4 thumbs up and please leave leave a testimonial
Posted on Oct 25, 2010
ThePoodleGuy
Mark Sanderson
  • 24 Answers
SOURCE: I have a Panasonic KX-TGA652 dual handset no
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Posted on Nov 21, 2010
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Dec 19, 2016 | Uniden DECT 6.0 Cordless Phone
How do i unmute the ringer on my vtech dect 6.0 phone
Hi Angie.
The manual for this phone can be viewed here:
http://cdn-media.vtechphones.com/ecp/documents/product_Product/1681/UserManual/6351/ls6425-3_manual_i3.pdf
On Manual Page 20 / pdf page 23, it says that if the ringer is muted for a single call, that it should work again the next time someone calls.
However. page 57 notes that the base ringer volume can be set between 0 and 6, so it's possible your ringer volume is not technically muted, but just turned all the way down.
Manual page 62/pdf 67 has a half-page list of other reasons that the ringer might not ring. (It can also be turned off, and there are different adjustments for both the phone and the base unit.
Hoing this lets you figure it out!
D
Dec 03, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I find messages/mute?
To hear your messages, press PLAY on the base.
To mute, press CLEAR on the base.
See pages 22 and 6 of the manual: Owners Manual User Guide for Uniden Dect2188 3 Dect 6 0 Cord cordless...
Feb 22, 2015 | Uniden Dect2188-3 Dect 6.0 Cord/cordless...
How do i turn off the silent mode which will not let me hear the phone ring
I have a Panasonic DECT 6.0 which is probably similar. Try the menu that sets the landline ringer volume. On mine, this is MENU #160, then use the up/down keys to set the volume. There may be a MUTE option somewhere there.
Oct 18, 2012 | Uniden DECT 6.0 Cordless Phone ID
Dect 6 Manual
my phone still wont ring and i have it full blast!!
Oct 26, 2011 | Uniden Cordless Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
Vtech cordless phone appears to be mute
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
Aug 24, 2008 | Vtech 9009111 Cordless Phone
Lands Phones Logo
71 people viewed this question
Top Thomson Lands Phones Experts
Marvin
Marvin
Van Allen II
Van Allen II
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
