Question about Dell Computers & Internet
Hi there I have a dell computer and I
Hi there I have a dell computer and I have always had a problem with it starting up,
now when I start it the fan runs at high speed and the computer will not start.
I shut it down and reboot it, the fan runs at normal,but the computer will not run the mouse dose not work. hope you can help me
thanks Eddie
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 162 Answers
It is the simple problem of your motherboard you can go to workshop and then checked your RAM and processor fan and it's chipset
Posted on Jun 29, 2009
Umy dell 1720 inspiron keeps rebooting, when the dell emblem comes up and start loading after it finish loading it starts over again
Did this problem start after a recent update? This could be the problem or a virus. Or possibly a power issue such as a bad power supply, cable or another internal component malfunction.
Try the following.
Unplug all external devices like external hard drives, printers, cameras and etc. Once these are unplugged restart the computer.
If this does not help, you can boot the computer into safe mode and perform a system restore if you are running a windows operating system.
-Turn off the computer
-Turn on the computer and as it is booting up keep pressing F8 until you get a menu
-Select Safe mode without networking
-Go to Start > Programs > Accessories > System Tools > System restore, choose a restore point before the problem started. This step may vary depending on your version of Windows.
If this does not work, you may want to call Dell if the computer is still under warranty, visit a computer technician, or continue to resolve the problem on your own.
An additional step is to reinstall the operating system but important files may be lost so save this as a last resort.
I hope this helps and if so thumbs up my solution.
Regards,
G33k
May 04, 2011 | Dell Computers & Internet
Hi My dell vostra 1500 laptop is not getting started.It is showing a black screen and cursor flashing in.Pleases suggest what could i do to get my computer back in shape.
this is most likely a startup(bcd boot)error. the only way to fix this is to run setup from your recovery partition (shift f10) when starting up the computer or use a windows 7 install disk and select repair my computer when it comes up instead of installing. let the program go through the first repair attempt to repair startup and then restart the computer without the disc in the drive. should repair the problem, but if not you can alway reinstall windows. heres a tip...stop downloading illegal movies/software because this happens when you download torrents and viruses.
Feb 01, 2011 | Dell Vostro 1500 Notebook
Hi I have a dell inspiron 1525 and it always worked fine but now when I go to turn it on the start up repair comes up and runs. Then a window comes up that says "startup repair cannot repair this computer...
hi zachgibbons,
Try this, restart your pc then press f8 continuously, this will take you to safe mode. then after that go to start>run> type in msconfig (windows xp) , and start>search> type in msconfig (windows 7)
this will open up the system configuration under the general tab
select the diagnostic start up then apply>ok>restart
Hope this helps,
thx
banaple
Sep 02, 2010 | Dell Inspiron 1525 Notebook
Hi, my name is Abimael and i have any problem whit my netbook inspiron mini 10 DELL. I canot conect to internet as i always do it. Display a message that it say Limited or not connectivity AND...
Click on start and select all programs.. Click on dell wireless utility.. You will have option to disable the dell wireless utility - please disable it.. Then restart the computer and try connecting.. It will work.... Still not working then unistall the drivers from the devi9ce manager and install the drivers from the dell website... (www.support.dell.com).. The issue will be definitely fixed...
Sep 02, 2010 | Dell Inspiron Mini 10 Notebook
All of diagnostic lights on the front panel are off . The system light turns solid amber. The system does not start yet. the fan always starts noisely. How can I fix the problem and start the computer...
Follow the instruction below>>>>
Remove the power cord from the back of the computer. Then open the side casing of the tower and unplug the 24 pin block connector from the motherboard. The 24 pin block connector looks like this >>>>>
Once removed press the on/off button on the computer to dispel and residual power from the motherboard.
Then connect the block connector again and put the side panel back on and then plug the power cord back in and try to boot the computer up.
If its still the same then the power supply inside the computer may need replacing.
Regards.
Aug 05, 2010 | Dell Dimension C521 PC Desktop
Hi Have a Dell Pc Windows 7 OS. it will not shut down unless I hold the button. Start-up in good shut down is always a problem
This is a possible malware or virus attack. Your system is encountering data or system corruption preventing it to execute the command during shut down. Best fix is to reinstall Windows 7 in your computer to erradicate all errors and make sure to install an updated security software (antivirus) afterwards.
Jul 16, 2010 | Dell Vostro 200 PC Desktop
The computer restarts on it own
Hi, go to the "Start Menu," type in the Start Search window; (power), in the next window there will be a "list" of Options in the "Task area, choose the "Sleep and Wake Up category, change the "wake up" this will stop the computer from starting up on its own. "Rating the solution on its helpfulness is appreciated, thanks."
May 12, 2010 | Dell Inspiron 1525 Notebook
Hi, Dell Studio 1535 cooler always starts, even if the system is not warm up. Plus mouse and keyboard work slowly. shut down computer, wait (2h.), but still the same. Checks the system load and temperature...
Try running the diagnostics on the computer to check if all the hardware is working fine. The diagnostics would take atleast 2 hrs to complete but would do a through check for the same. I have come accross the same issue on the said laptop and we have ended up replacing the system fan for the same.
To run the diagontics
1. Shut down the system
2. Press and hold the FN key on the keyboard and press the power button to start the system
3. Follow the screen prompts to run the diagnostics.
Note and post back any error codes if any
Thanks for using fixya
Proton
Mar 15, 2010 | Dell Studio 1537 Laptop Computer PC...
At start up i always have to input the date &time etc why?
You have to change the on board battery.
Thanks, PREM
Mar 29, 2009 | Dell Latitude C610 Notebook
Open Questions:
Dell Printer@^+[1]=855-221-4867@&@tech Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Computers & Internet Logo
62 people viewed this question
Ekse
Thomas F. Schneider
