How old is your battery? and did you keep it on charge when it was not in use?
Most rechargeable batteries require a spindown, where as you completely discharge the battery before recharging it again.
I know you aren't wanting to hear this but in all probability that battery is spent and will need to be reconditioned at a battery place, however, it will cost almost as much as a new one it would be your call.
if you have a ohm/volt meter it might be possible to look at the charger and get a volt/amp reading and then test it see if it is putting out the proper voltage it could be putting out a trickle charge and it would take forever to charge it.
there is one other situation to look at and if the beater brush or motor is causing a resistance it will pull a battery down quick.
I do not own this vaccum so I can only guess as to the possibilities.
SOURCE: My Hoover Linx is not
I think you have 2 problems:
1. The LiNX gets clogged somethings in the head unit and the clog is difficult to see. Remove the head (via the push button). and clean out the clog. I do this with a lenngth of coat hanger wire that I bent a small hock on to the end.
2. If the roller stops turning it can be caused by one of the power wires to the moter getting severed in the swivel connection in the head unit. This has happened to us twice. I took the unit apart (a pain) and was able to fix by soldering and taping wires. However, Hoovers design is not great in getting power to the motor and this may recur. I love these vacuums and I hope they engineer a more robust wie feeding solution.
