You can simply restart your Kindle fire device to fix this issue: A direct restart deals with the issue of the Kindle Fire Micro SD card not recognized. If the direct reset does not fix the issue, then you have to check your Micro SD card. There might be issues with your micro SD card.
please remember the purpose of having a external micro sd memory in a tablet is mainly for media/ work / school purposes. most your going to be able to put on the cards is information relative to what i just told you and application that you have download from your APPLICATION STORE depends on the OS ( operating system you have on your tablet will determine how you can move them from your tablets internal memory to the tablets external sd card memory
here is a bing search on how to move items from internal memory to external for both tablets and phone. i suggest you watch multiple videos and refine your search based upon your OS and continue to search.
It may be that the device is fitted with only sufficient memory to run the O/S and needs an additional memory card???
what is the make and model of the divice. Please add that detail and repost the query
Post an answer to this question...Dear Brandy Pl long press power switch to make it OFF. then take memory card or sim card from the set. Then power ON if it open go to setting to factory reset and make it rest. Since more applications crunches the RAM and freeze often happen. try to load or move the application to the memory card if any. this will save tabs internal memory. If problem not solved take to the service center. thanks
Sure you have enough free memory? try to have at least twice the amount you really need. The free memory should be internal memory, not an (Mini, micro) SD card.
Try to remove everything from that app, reset the tablet and try again.
Move your apps to the SD card via Settings - Apps. You have to move each app one at a time, and some will not move. Then clear your browser cache. Delete old messages, especially ones with photos and videos with them.
