Aastra Telecom Aastra M-9120 Caller ID Two Line Phone M9120, M 9120 Logo
P
Peoria County Posted on Jul 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get caller id to display on both lines (service enabled, but doesn't display 2nd line caller id)
Is there a work around? line splitter?
Thomas Smithbrother
Level 3:
Top Expert:
  • Aastra Telecom Master 3,698 Answers
  • Posted on Jul 02, 2014
Thomas Smithbrother
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
957167
Points
10318
Www.aastrausa.com
Panasonic KXTG9581B caller information is not displayed in india. My phone line is caller id subscription enabled. help me to how to set caller id in the base unit
It may be enabled, but normally you have to pay for it.
Page 54 of the manual. It is automatic.
Using Caller ID service
Important: This unit is Caller ID compatible. To use Caller ID features, you must subscribe to a Caller ID service. Contact your service provider/telephone company for details.
https://help.panasonic.ca/viewing/ALL/KX-TG9581/OI/TG9581_PNQX6371ZA/TG9581_PNQX6371ZA.pdf
1helpful
Need a caller ID that hooks up to land line phone line and shows on television screen.
Contact your phone service provider to setup caller ID and ask them if they do the TV service as well
the service provider has to enable caller ID before any plug in box will display the number there is a charge for the service depending on the package you have
1helpful
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
KX TG1061 panasonic phone called id not working in India
Try connecting your phone to some other phone lines in which the caller id is working properly and this way you can check if the problem is with your device or line.
For all the phones to display the caller information properly, CLID (caller line identification service) should be enabled for your landline connection. Please contact your phone line provider to enable this service and you should be able to see the caller id information in your panasonic device.
I hope this is helpful to you
thanks
Please rate the solution
1helpful
Polycom SE225: my verizon line provide caller id does not displa
Due to the age of the SoundPoint Pro, it some of its features are not compatible with newer phonesystems, such as CableVision. There are no software updates for the SoundPoint Pro, and as long as the Caller ID is enabled there are no other settings or adjustments that can be made to workaround these kind of problems unfortunately. I recommend contacting your service provider to see what kind of caller ID signaling they are using; most likely they will be using a newer digital system, or MDMF which is not backwards compatible with SDMF or earlier CID receivers.
1helpful
CALLER ID NOT DISPLAYED.DISPLAYS EXTERNAL CALL
Caller ID in the USA uses the FSK standard. For the most part, callerID in India uses DTMF (although I have heard of some FSK usage).
I am currently living in New Delhi and have an Airtel home phone line.My switch uses DTMF. I went to the Palika electronics bazaar (I awaysuse shop number 266 near gate 5, they seem to be a little kinder toforeigners as far as the "final price") and purchased an DTMF to FSKconvertor. My US phones now show caller ID information, although usingUS number seperations ### - ### - ####. I paid R500 but you couldprobably get it for around R400 if you are willing to put in the timebargaining. It looks like they are also available on Indian Ebay.
Mine says UST001B. It looks like these are low volume items becausethey stuck the components into a box marked "DSL Splitter" It works toconvert the caller ID as advertised.
2helpful
3answers
Uniden CXA15198 not showing caller id
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Try this and the problem is solved.
Nrupesh
19helpful
7answers
Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Top Aastra Telecom Lands Phones Experts
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
