My combination won't open my manual "dial" lock on my Theftguard safe. What's my next step?
The dial spins but doesn't feel "right"... no resistance. I know the combination is correct. When I dial in to the last number I go very slowly, as recommended in the owners instructions but the resistance I usually feel isn't there.
Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2
Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3
Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
NOTE: If your safe DOES NOT have a key, skip Step 3.
Turn the dial to zero.
Insert your key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes 31-10-31
Insert the key; turn right.
Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes 31-10-31
Electronic Locks 31-10-31
Insert the tubular key into the lock to the left of the key pad.
Turn the key all the way to the right until the plunger pops out.
Press the five-digit factory code. The green Proceed light will come on.
4 Digit Combination Lock 31-10-31-10
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Are you sure that you are turning the dial correctly?3 Digit Combination Lock 31-10-31
Call the number above, give them your model #, the serial number
(located on the right side of the safe next to the model number), and
your key code. They will provide you with the combination to your safe. your combination number will be provided to you immediately.
Also, you can try
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial
CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door
open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number
FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO
(2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE
(1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Here is the turning sequence: General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers). BEFORE YOU START Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right) three times. We also recommend to try the procedure with your safe door open first. Then follow these steps: TURNING SEQUENCE 1. Start the dial on 0 (zero). 2. Turn the dial to the RIGHT, passing your first combination number FOUR (4) times and stopping at that number on the fifth time around. 3. Turn the dial to the LEFT, passing your second combination number TWO (2) times and stopping at that number the third time around. 4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time and stopping at that number the second time around. 5. Turn the dial to the LEFT, to the last combination number and STOP. 6. Insert the key in the cylinder lock and turn RIGHT to open. Your safe should now be opened.
To bad you dismantled. Here is the turning sequence: General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
