SOURCE: Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
SOURCE: My printer says unable to
Machine Error 46 - Purged Ink Box Full
The machine counts all purge (cleaning) operations in order to prevent
the internal ink absorber box from overflowing with purged ink. An
"initial purge", for example, advances the purge counter by 187 + 420 =
607. When the purge counter approaches 6400, an internal "Machine Error
46" is generated. Further purge operations are prohibited, and therefore
the printer becomes unuseable.
When an internal Machine Error 46
is generated, the user will see an "Unable to Clean" external message
and will be unable to use the printer. The "Unable to Clean" external
message can relate to many different internal error codes however.
The
If there is a Machine Error
46, it is necessary to dismantle the printer, replace the ink absorber
box (or possibly break the ink absorber box open and clean its absorbent
sponges under a tap), re-assemble the printer and reset the purge
counter to zero.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: my brother j220 displaying unable to init.49 how can i remove it
The machine has either a mechanical problem or there is something in the machine such as a paper clip or scrap paper.
open up machine and inspect it. use compressed air if needed to clean everything out. If this does not work then unplug for 5 minutes and then re-power on and see if it comes back if so you will need service on it.
here you will find user guide to further assist
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_J220_J265w_J410w_EN_2577.PDF
