Question about Samsung LN-S4092D 40 in. LCD HDTV
Samsung TV "weak or no signal"
Cannot bring TV on
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: weak or no signal message
Is this a joke? How am i suppose to get help?
Posted on May 29, 2008
Weak or no signal
Either the connector on the set is bad or something is burned out. Try connecting to a tv or ext antenna and see what happens.
Apr 01, 2014 | Samsung Televison & Video
Unable to set TV channels on Samsung LED TV
Check the orientation of the antenna. If the transmitter you're trying to tune is very far away from your home, the signals will be very weak, that the tuner inside the TV can't catch. If this is the case, the orientation of the antenna is very important.
Dec 03, 2013 | Samsung Televison & Video
Samsung 50'' plasma model ps50b450b1wxxu keeps losing all stored channels and needing re-tuned,tv says weak or no signal, it is only 3 weeks old, is it something i,m doing wrong or is the tv faulty?
If you are always needing to auto program the tuner then I suspect a faulty main board. Bring it back as it should be under a 30 day return policy..
Nov 03, 2009 | Televison & Video
Samsung lcd tv is saying low or weak signal when trying to tune it in
you can only use your tv to scan for channels with an antenna or if you have that tv hooked to cable television. use your Directv receiver to scan for channels, if you have an antenna hooked up to it. --------------- click this link for more help http://www.highdefforum.com/directv-forum/77638-new-lcd-tv-d-sd-no-weak-signal.html thaNKS.
Jul 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
"Weak or No Signal" message on Samsung 26" LCD TV
I pressed mute on my television and about 5 minutes later it said weak or no signal.What do I do?
Feb 24, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
Weak or no Signal issue when connected to my TV.
Yes weak signal. Also closing the laptop lid puts the computer in sleep mode.
Jul 07, 2017 | Digital Lifestyle FA1B32Z 32 in. LCD...
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Dec 17, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung LN-S4092D 40 in. LCD HDTV Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
