Brother DCP 115C All-In-One InkJet Printer Logo
A
Anonymous Posted on Jul 01, 2014
What and where is the ink box? - Brother DCP 115C All-In-One InkJet Printer
Maintenance box for epson wp-4020 :must it be changed absolutely to continue printing when there is enou ink ?gh
Yes, you need to change the maintenance box when it is full. The box stores the waste ink that goes through the print head during a cleaning cycle. Without changing this, you could get ink throughout the printer. This could damage the hardware in the printer.
The maintenance box for the WP-4020 is available here: https://epson.com/Accessories/Printer-Accessories/T6710-Ink-Maintenance-Box-T671000/p/T671000 . You can see the replacement instructions here: https://files.support.epson.com/htmldocs/wfp4020/wfp4020ug/index.html .
I hope this helps.
My brother printer j140w problem massage coming on screen "ink box full"
It may refer to the ink "overflow" box. When your printer cycles, it will dump a bit of ink which goes into a collection box. Most likely, that box is full and needs to be emptied, replaced, or whatever.
What is the best solution for ink box near full in DCP-J105
The ink absorber box or flushing box is nearly full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.Solution Replace ink box replacement Or you can try to vacuum the toner out of the ink box Ink box is container to the far right . gl edward austin associates
Ink absorber full brothers
Sir/Madam
The ink absorber box or flushing box is full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.
The ink absorber box or flushing box will need to be replaced.
Other reasons for cleaning are:
  1. Machine automatically cleans after clearing a printer jam.
  2. Machine automatically cleans after sitting idle for more than 45 days (infrequent use).
In Case Your Not Able To Clear Your Problem Then Go to Official Brother Printer Website: http://welcome.solutions.brother.com/BSC/public/as/hk/en/faq/faq/000000/002700/000051/faq002751_000.html?reg=as&c=hk&lang=en&prod=mfcj6710dw_all
Or
Still Having problem Then Follow Us For On:Brother Printer Support
2answers
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
1helpful
Where do I find ink supply level on epson 2200 ink
Open the Epson Printer Utility, Click on the printer name if you have more than one printer then OK. Click on Epson Status Monitor at top. A dialog box will come up telling you if any ink needs to be replaced. Click on the OK button in this box and this will take you to another dialog box which will show you the amount of ink left for each color.
2helpful
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
1helpful
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
7helpful
Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
6helpful
My brother mfc 440cn read unable to clean error46
Its Ink Absorber Box is full. Inside the machine, in the back and hidden under the covers is a large plastic box with thick, felt pads packed in it. Every time the machine cleans its printheads, it squirts ink through all its nozzles, collects the mess, and pumps it into that box. After a few thousand cleaning operations, it decides the box is dangerously full of ink and throws up that Error 46.
Getting to the Ink Absorber Box (part number LP1270001) is fairly complex. I think it's time to ask a tech what he/she charges.
Norman Weimar
Norman Weimar
k24674
