Use this link to parts schematic http://www.paslode.co/uploadedFiles/Cordless_16ga_straight_finish_Parts_Diagram_Schematics.pdf
Remove filter cover (1) and filter (2) remove 4 x cap screws (3) then remove top cover (5) disconnect spark plug lead and fan supply led then rotate head anticlockwise and lift it off, slide out front extrusion (56) remove 2 x screws (68) at bottom front of gun (1 each side) remove 4 x screws (80) from left hand housing cover and 1 x screw (59) from left side of handle bracket (83) Note: Do not remove right hand screw from bracket (83) you will now be able to lift the right hand housing and remove it from the groove in the nail channel, the barrel, combustion chamber and nail channel assembly can now be swung up and out of the right hand housing
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
with them.
If
Paslode
heatman101
Bad o-rings or bent firing pin...
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
