Kymco UKhttps://www.kymco.co.uk > AGILITY-eq35fa
QUALITY, STYLE & PERFORMANCE! The new Agility compact 8 mph scooter offers high performance with comfort, making everyday journeys a pleasure!
Maximum Speed (Kph / mph): 12.8 Kph / 8 mph
Wheel Type: Pneumatic
Calculated Range (Km / Miles): 40 Km / 25 Miles
Turning Radius (mm): 1560 mm
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
be sure of model etc & order a manul from the dealer,then once read the basic guides,if no joy then book will advise you to get in touch with a qualified dealer.
