Yamaha Portable Keyboard with 61 Touch-Sensitive Keys and General MIDI Logo
A
Anonymous Posted on Jul 01, 2014
How do I fix my Loose USB port on a midi keyboard?
Becketts Music Ltd
Level 2:
Novelist:
  • Yamaha Expert 167 Answers
  • Posted on Jun 18, 2015
Becketts Music Ltd
Yamaha Expert
Level 2:
Novelist:
Answers
167
Questions
Helped
65816
Points
403
If the port is still intact then it might just need to be resoldered. USB ports however to get strained and basically fall apart. Purchase another and solder it to the board. If you are not confident about doing this take it to your local Yamaha service centre.
HomeContact Us About UsAll CategoriesAmplifiersBanjoBaritone Horn...
If using link below please suply model number so correct part can be ordered. HomeContact Us About UsAll CategoriesAmplifiersBanjoBaritone Horn...
Midi Keyboard
I suggest taking it to the shop. The connector may need to be re-soldered, and if you make a mistake the keyboard could be damaged furthur.
May 04, 2015 • Music
How to fix loose USB on M-Audio Keyboard
Uscrew the case, desolder the USB socket from the circuit board. Buy a identical spare from any electronic shop using the broken one as sample. Solder in new USB socket.
USB sockets has only 4 connections - easy job.
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
M-Audio MIDI Keyboard Controller's Loose USB Port
Open up and solder in a new Type-B USB socket. Get spare from any electronics parts supplier - it is a generic part. Just 4 solder points on PCB board.
Connect casio LK94Tv keyboard to a PC via midi
Your keyboard only has a USB port.
You need to buy a std USB printer cable (A-B).
Download the drivers from Casio.com
Instal the driver first and connect the cable when asked to.
Once connected, the PC will have software MIDI-IN and MIDI-out for your LK94TV
Sep 04, 2013 • Casio Music
Hello guys, i have a problem with my midi keyboard. My PC doesn't recognize the USB connection and i can't find any solution.
Well first start by verifying USB port works by plugging in a hard drive or something thus proving you have a good port and USB Cable. At which point hook the keyboard up ( and make sure to properly install drivers provided on cd with purchase) being a pc this may take several attempts to install. What software are you trying to control? Reason? Logic? Fruityloops?
1helpful
1helpful
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
