Good Afternoon Friend,
I understand that your Frigidaire microwave, model# PLEB30M9ECE, is cooking, but has stopped beeping. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try any cooking cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: Beep off
No theres no beep shut off. You could open the unit and risk getting the heck shocked out of ya and disconnect the small speaker mounted on the circuit board. You should take the unit to someone who knows about microwaves to do this for you.
SOURCE: GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
SOURCE: Oster Microwave/Convection/Grill
first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
SOURCE: Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
