My abs scanner is teling me a u1300 code . what is this
Hello
When the service engine soon light (Also called the check
engine light) is turned on this is to alert you to the fact that
powertrain control module (computer) has detected a failure somewhere
in the systems it controls, this can be the transmission or the
engine or emission system, there are fault codes set in the modules
memory for these faults. What needs to happen now is to have the
powertrain control module scanned with a special tool called an OBD2
electronic engine control scanner or a OBD2 code reader. Once the
code(s) are read then you must perform the diagnostics for each code
and make the appropriate repairs based on the findings of the
diagnosis that was performed, this is called doing "Pinpoint"
testing.
