We had a power out today and when the power returned the phone didn't work anymore, The ANS on/off button and the In use light flash together at the same time. The phone is on a surge protector and unplugging the phone did nothing. Anyone know what is wrong or how to fix it? Ive only owned the phone like 6 months =/
SOURCE: vtech 7100 phone
Download Vista driver from VTECH website:
http://shop.vtechcanada.com/vtt/en/support/downloads/software/USB7100_Software_vista.cfm
After running the executable make sure that your normal speakers and microphone are set as the default ones, otherwise VISTA may try to use your phone as speakers and microphone.
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
SOURCE: vtech phone problem Model # LS6117-5 DECT 6.0
take out battery for a few seconds then put back in. My phone just did the same thing and it kixed it. Not sure why it happened though
SOURCE: Phones stopped working. They only read
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
