SOURCE: 1994 Honda Accord LX will not start 190k miles
They are two most common problems with this vehicle that will cause it to do this 1 bad distributor and the other bad MAIN relay. I need you to check for spark and gas when this vehicle does not start, contact if you need help checking when you figured out whats missing when you fail to start I will give you the answer, Good luck and thanks for using FIX YA
SOURCE: 1998 mitsubishi mirage 1.5 liter 5 speed wont start
If you have spark, try changing the fuel filter. If you don't have spark, get back to me.
SOURCE: engine cranks but won't start
I firstly would check relay. You can use an ohmmeter to check the resistance of the relay. If you get a reading, it is good, If not it is bad. Than disconnect fuel pump wire harness and do the same.
SOURCE: Dies after running about 2 minutes
It's got all the symptoms of a leak in the fuel line. You may want to start backward at the tank and work your way all the way to the carb to find it but it would be surprising if it was something else. All the best.
Greg
SOURCE: 2002 express 1500 van, will not start
Also, when you have the dog house off, remove the distributor cap and check for moisture.
