Is the bobbin full of thread, and is the needle threaded?
These are very inexpensive machines; some will only sew with what is in them when delivered, then you buy another. :-(
I think you are saying no stitch is formed also referred to as the needle not catching thread. Below offers a variety of diagnoses and solutions which are straight forward.
Below is general advice quoted from 6 common sewing machine problems solved:
Skipped stitches are usually due to a bad needle. The needle may have become damaged or bent by sewing material too thick for the needle, forcing material through the feed dog, or hitting a straight pin. If the problem seems to be consistently reoccurring, it may be due to forcing the fabric. Sewers should allow the feed dog to pull the fabric and only use their hands to guide the fabric through the feed. When sewing knitted fabrics, using a stretch needle can help prevent skipped stitches.
Below is a video showing how thread is hooked into a fabric:
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
As a general rule of thumb, satin stitch is obtained by selecting zig-zag, turning stitch width up to 3 or 4 and stitch length to 0.5. If you have a clear plastic open toe sewing foot, put that on to help view the area.
If you are doing applique (attaching pieces of fabric to another surface) with a satin stitch, you may also need to use tear away stabiliser underneath or interface the fabric first, it depends on what/where you are doing the satin stitch onto.
And a nice machine embroidery thread will give you a much silkier appearance than plain thread.
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figureif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
