The camera is a wonderful Kodak product and takes beautiful 8.5 Megapixel photographs. When you save the pictures to an SD card, you must at some point remove them digitally from the card. Either by linking it to the USB cable and going from there to your PC, OR by removing the SD card from the camera and inserting it into an SD card slot in your computer, printer, or card reader. Occasionally the card readers such as the ones in your PC, printer, or card reader devices do not connect properly and will only transfer part of the data, resulting in pink ugly lined photographs. This problem can be fixed by using the USB cable instead of the built in card readers in your other devices.
Cycled through display options, still couldn't get viewfinder image. Checked images already on card, and they showed OK, so screen operating properly. Went back to viewfinder mode, got lots of horizontal lines across screen. Realised I could do no more, so took camera to shop it was bought from, who checked it and said it had an electronic problem that neededprofessional repair facility, so camera has gone for an estimate of repair cost.
Hi . .
I downloaded the manual . . found I needed to replace the 3 volt lithium battery
located on the underside of the hand grip for the zoom.
Changed the battery . . . No red flashing icon in the viewfinder.
Cheers
Steve
It shouldn't be there, but as the optical viewfinder is completely separate from the photographic light path it's nothing to worry about either.
Normally it's caused by either a hair or fibre which has somehow entered the viewfinder (rare) or more commonly by a fine scratch across the front window to the viewfinder. Also check the rear viewfinder viewing lens as the same damage could occur there but as that lens is relatively protected it's unlikely.
Any further fixing involves dismantling the DSC-V1 and possibly sourcing spares made of purest unobtanium so if the camera works perfectly well then leave the screwdrivers safely in the toolbox for now.
Hi. From past experience I would say that these symptoms suggest the early stages of CCD failure. It usually starts with lines etc as you describe and progresses into wavy, blurry pictures or partial pictures and eventually the ccd just goes black. If it is CCD failure, the camera will usually still work when viewing pics that are already on the card.
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factory defect ccd imager. the company recalled those units and replaced with a stronger version of ccd imager ( they are still doing it). check it out.
I don't think that this is a defect. I own an A60 and there is an horizontal line running through my viewfinder. I use my LCD screen more often then my viewfinder, so I've never seen the blur. However I'm pretty sure that your camera is fine.
