In plain English, the Percentage setting on your de-humidifier is the percentage of moisture that you want to maintain in the air. Relative humidity level range from about 10% (VERY dry air) to almost 100% (VERY damp air). When relative humidity is 100%, water vapor in the air will turn into rain, condensation, dew, snow or frost. 50% humidity is usually a comfortable level, but that will also depend on air temperature. The more moisture there is in the air, the warmer it feels and conversely. Warm air will hold more moisture than cooler air.
Your body is cooled when moisture on your skin evaporates into the air, carrying body heat with it. As the humidity in the air rises, less of your body moisture is able to evaporate and thus your body feels wamer. Lower humidty allows moisture from your body to evaporate more quickly and you feel cooler, both at the exact same temperature.
