Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
A
Anonymous Posted on Jun 30, 2014
Why not print a4 photo quality on canon mg2440
5 Related Answers
Anonymous
  • 3614 Answers
  • Posted on Sep 09, 2008
SOURCE: printing broblem
first check the paper you are using, and i wnat to know if your are using an orig. ink.
let me know
thanks
Anonymous
  • 177 Answers
  • Posted on Dec 27, 2008
SOURCE: Photo print quality Canon i860
You might be running low on toner or ink. In this case check out the ink/toner capacity left. it might even be a faulty cartridge if bought new, or a faulty printer, but it doesn't sound like it.
Suricatta
Pedro Jesus
  • 92 Answers
  • Posted on Jun 26, 2009
SOURCE: paper jammed but no paper is jammed.
I guess there is a small piece of paper near A4 sensor...
Try carefully to dismantle and clean...
Good luck
Best Regards
Anonymous
  • 8 Answers
  • Posted on Jun 09, 2010
SOURCE: poor color quality (Canon Pixma pro 9500)
recalibrate the printhead, clean the printhead. In the printer driver you need to select the right paper.
termistor
Patrascu nicolae
  • 85 Answers
  • Posted on Mar 29, 2011
SOURCE: I am trying to print
trying to print multiple pages(3-4)in case you have not used for some time printer, photo paper quality to be good or another cause may be that ink cartridges are running low or is refiled
1helpful
How do I scan on a Canon MG2440
I understand that following manual is not easy so if you still face any issue with scanning then you can contact me at 1800-969-3032
1helpful
7answers
Canon PIXMAMG2420. Where can I get a manual?
We also provide the Canon Printer customer Support, Canon Pixma Support Number, software installation, software upgrade, cartridge jam, paper jam issues and much more.
856 269 2666 Canon Pixma Printer Support USA Canon Printer Support
Using Easy print
If you are using Easy Photo Print ( highly recommended) select your images, then select your paper type and size, then select your layout and print.
If you are printing direct or wirelessly, your options are more limited to A4 or 6x4".
Canon MG2440 Reset
I think 5b00 is a print head failure, which means one of the cartridges is possibly faulty. Do you have any old cartridges you can put back in to see if the error clears?
2answers
What to do if i have ink leaking?
Although blunt, the previous answer is correct, except I would opt for an Epson printer as they have superior printing technology and lower cost compatible inks. After using Epson right from dot matrix to the first colour Epson to the latest a4 and a3 printers dollar for dollar (pound for pound) you get a better quality photo output and you don't have to pay for a replacement head like HP models, or suffer decreasing print quality over time as with Canon.
1helpful
2answers
2answers
I have a canon mp 240 and it Prints fine if you only need half of the document. It cuts everything in half! Like it reads the header wrong or blows up the words or make extra spaces. How can I get it to...
I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I set my printer so my printout fits the paper size I am using?
Solution: Use the recommended Print Area MP240
Printing Area title-bar.gif To ensure the best print quality, the machine allows a margin along each edge of media. The actual printable area will be the area inside these margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. (o_darkblue13.jpg)
Printable area (light blue):
The area where it is possible to print. (o_lightblue14.jpg)
However, printing in this area can affect the print quality or the paper feed precision.
o_area15.jpg i_note.gif Note
Borderless Printing
By selecting the Borderless Printing option, you can make prints with no margins.
bullet_s.gif When performing Borderless Printing, slight cropping may occur at the edges since the printed image is enlarged to fill the whole page.
bullet_s.gif For Borderless Printing, use the following paper.
- Glossy Photo Paper "Everyday Use" GP-501
- Photo Paper Glossy GP-502
- Photo Paper Plus Semi-Gloss SG-201
- Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
-Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced quality. Use them only for test printing. You can perform Borderless Printing on plain paper only when printing from your computer.
bullet_s.gif Depending on the type of paper, Borderless Printing may reduce the print quality at the top and bottom edges of the paper or cause these parts to become smudged.
See A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See Letter, Legal.
See Envelopes.
sikaku.gif A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
3.73 x 6.80 inches / 94.8 x 172.6 mm
* This page size can be used only when printing from your computer.
o_ap_069.jpg o_darkblue6.jpgRecommended printing area
o_lightblue7.jpgPrintable area
sikaku.gif Letter, Legal
Size
Letter
8.00 x 10.69 inches / 203.2 x 271.4 mm
Legal*
8.00 x 13.69 inches / 203.2 x 347.6 mm
o_ap_074.jpg o_darkblue4.jpgRecommended printing area
o_lightblue5.jpgPrintable area
sikaku.gif Envelopes
Size
European DL*
4.06 x 7.12 inches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1 mm
* Envelopes can be used only when printing from your computer.
o_darkblue8.jpgRecommended printing area
1helpful
Hi, I have a Canon i4600 printer. I have not used it for awhile but am now consistently getting parallel white lines 2mm wide across an a4 B&W photo print. Any ideas Thanks
The ink-jet printers if not used get the ink dry and this can affect the quality of the printing as well as the print head. So it is recommended you use it every once in a while to avoid ink getting dried inside.
2answers
Canon Printer IMAGE QUALITY
use the canon software and set up fax seperately.
2answers
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
old marine
old marine
ZJ Limited
ZJ Limited
