The compartment for the dvd/cd, won't eject most of the time, when it does it will do it a couple of times and then stop working. It seems like it is hanging up. Any ideas? We have quit using it but if it can be fixed we would like to use it again.
SOURCE: bose 321 can't select cd/dvd source and won't eject
this is a belt driven drawer there is a little gear made from plastic . the cause is there are teeth missing from the gear .due to /pushing drawer manually or forced shut / or kids / now this this will have to go to bose for repair i was a bose agent for repairs and yes this is the worst bit it will cost £140 TO £200 POUNDSthe unit has locked out this is a common problem with this unit bose do not actually make this unit its a generic design the company should stick to speakers only .there are better built systems than this,people think they are buying the best its the name game again i have been in this trade a long time my moto is always buy sererates if your cd/dvd goes wrong you can pop a new one in rather than loose the lot . bose are not good on servicing slow and un reliable depending on where you are . uk not good /america dont know sorry to deflate you i have 6 off these units waiting for parts all with the same fault . people panic and take a knife to the drawer to get there beloved cd out this does even more harm a drawer will cost £47.00 a cd £ 10.00 ..TO Replace it can be retrieved so there it is. if you are in the uk my email is [email protected] we can talk if you need further assistance if you send it now you will not get it back before christmas best regards kirk brown
SOURCE: CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
normal issues with cd/dvd trays - gear/rubber of the tray transport worn out.
manytimes it helps if you always keep a cd/dvd in the tray (don't keep the tray empty)
it may also help if you can keep the bose 321 vertical.
SOURCE: Bose 321 tray will not open
If it's flashing on and off, then the DVD drive is the least of your problems. Check to see if there is a dual-voltage switch on the bass module. (if so, set it to 120v if you're in the US) As for the DVD drive--> Try another reset by unplugging the power for at least 30 seconds. Plug it back in, "Bose 321" will appear and disappear from the display, and then press the eject button before you power it back on. Wait about 3-8 seconds. If the drive won't open, it will probably need a repair. $150 for repair w/ new warranty through Bose- 800-367-4998.
