LG RH177 DVD Recorder/HDD Recorder Logo
Posted on Nov 06, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can this play all regions?
I was wondering does anyone have a code to make this recorder play region 1 if this is possible
thanks
Anonymous
Level 2:
  • Expert 102 Answers
  • Posted on Jan 11, 2008
Anonymous
Expert
Level 2:
Answers
102
Questions
0
Helped
43371
Points
266
Press Setup
Scroll to Lock
Press 0 (7 times)
A message will appear saying it is region free
Steve wonder
Region code 1 is for the USA. The player must be either region 1 or a multi region player to play such DVD's. Is it possible that the DVD's from Fox are from anther region placed in region one cases? It depends also where you got the DVD's from, there are a lot of counterfeit ones out there. Which to be honest will not work at all.
2answers
How do I unlock the region code on my BDX2250?
sorry. I can't say because I don't know if you are fixing your car or stealing one. Best bet is to call the dealership or hit up google.
2helpful
Im wondering if anyone know how to turn off the region zone for a Sony DVP-FX750. It was purchased in america with a zone 1 & we have zone 4 in Australia. I've tried to burn a DVD to play, but...
This question is one of my most frequent on FixYa.
There is no "region-free" or "region 0" setting for any DVD player/recorder. Only DVD media can be region free. Every single offer to set a player or recorder to region free that I am familiar with has been a scam. The reason for this is to prevent DVD piracy.
Most DVD players and recorders (SONY included) have provisions for making a maximum of THREE changes to their region code. A fourth attempt at changing the region code will result in the player/recorder being turned into a paperweight.
Bkhopkins- in your case, you will be able to change your region code from region 1 (USA) to region 4 (AUS). Doing so will leave your player with 2 more changes, maximum. Check your manual for the procedure and the exact number of changes you are allowed. Please be aware that after you change to Region 4, any Region 1 DVD's will not be viewable unless you switch back, which will use another of your three changes.
You have an alternative to salvage your DVD's by downloading a program called DVD Shrink. This program is capable of removing the region code from your DVDs and saving them as region-free at the sacrifice of some quality. You will at least the be able to view your US DVD's without sacrificing a region code change on your player.
Good Luck, and Thank You for using FixYa!
Hi i was after a no region code for a dvd player!!!
To unlock the DVD code its defends upon what region you belongs or from were you bought the DVD unit. Just click this site to hack the region code ; http://www.videohelp.com/dvdhacks
To keep it simple, this means that DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
The geographical regions are as follows:
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs
Hope it may help you;
Regards;
VOTIT
Unlocking region code
Hi. Same problem re TOSHIBA portable DVD player bought in the USA, model SD-P91SKN. Wonder if anyone found the solution to unlock it to multi-region? Thanks!
2answers
Need to play region 1 DVD in region 2
hi
try a search on your dvd here check for region codes dvd
riz.
5helpful
2answers
2helpful
Playing region 1 DVDs in LG DR165 receroder
go to dvd set up then scroll dow to lock then push 0 seven times
2answers
Region free codes
I bought a panasonic portable dvd player for the kids for christmas, unfortunately it displays wont play in the region. I do not have a code for it nor a remote control. The model is LS850. Can you help.?
Go Video Unlock Code
check the menu settings or (setup) on the dvr 4000 to see if it has options to enable or disable parental lock or to change region settings to region 1.
also the dvds you made are they +r or -r on what brand dvd record disc on dvd-r this may solve the problem but use a quality brand disc like memorex dvd-r it is compatible with many players and recorders also make sure the disc you made on the recorder were finalized.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
