How can i find insruction manual for my Motorola Bluetooth? I don't know what model it is.
Motorola Support Find Answers Motorola Mobility Inc Go here to locate your product where you can get answers.
SOURCE: help hooking up my bluetooth ear piece
ok it took me a while the way u need to do this pairing is easy they just explain it really bad.
in your phone find the add device
press the call button till the purple light comes on
open the FLIP(microphone part AND THE EAR PEICE!!! people for get the ear peice)
press ok and have your phone start searching
once it finds the device press 0000 for the pin
your all set i almost sure this will work!!!
SOURCE: motorola blue tooth headset
http://www.motorola.com/mdirect/demos/headsets/HS810_HS850_Quick_Start_Guide.pdf
Try that page. It'll show you how to pair it.
SOURCE: motorola h700 blue tooth
You can download a pdf of the instructions here:
http://www.motorola.com/mdirect/manuals/QSG-H700_9499A88B.pdf
SOURCE: have motorola h710 bluetooth headset and no
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
Do you have a picture of it or could you post a picture?
