this isn't a pool pump but a 4 gal backpack sprayer , ive got one of these there great and allow you to spray a bunch with out reloading it , sorry to hear yours got problems , once id left mine with a bit of rust proofer in it and it did something like u described , what I did was dump near boiling hot water in the tank and give it several pumps , what ever it was that was blocking the pump up got dissolved in the hot water and went right on out the end , I don't leave it full any longer as ive learnernt my lesson
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Just checked on this and , The Manufacturers Website has all of the Parts that you would need. General Search the Model Number and Brand and it is Right There.
