Need to control volume on tv
0030 0049 0050 0066 0076 0101 0102 0119 0143 0152 0154
0166 0181 0195 0209 0217 0240 0307 0318 0365 0379 0414
0421 0488 0492 0601 0624 0637 0642 0827
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: needing the codes for remote to control tv
The code is ..0000,..Step 1. Turn the TV on. Step 2. Press the TV button the remote. Step 3. Press and hold the SET button until the LED blinks twice, then release it. Step 4. Enter the four digit code, the LED will blink twice. Step 5. point the remote at the TV and press the POWER button, the TV should turn off...hope this was helpful...
SOURCE: I need the code for
Hello:
Codes for your remote control that control Samsung TVs include:
SOURCE: i need a code for control remote ucr4220 one for
Try for
Samsung 0030, 0060, 0178, 0702, 0812
If you need a manual you can download on from
http://www.oneforall.com/support/manual
Let me know if you have any other questions. Please rate this solution. Thanks
SOURCE: I need the codes for One For All Big Easy URC-3300B07, to program Samsung Slim TV
If you wish to get setup codes, three digits, four
digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to
some popular model remote controls are given. Select the 'Timeslide'
option from the drop-down list by the 'Sidebar' at the display
window. It will make search easy. Surf the site patiently.
