Toshiba 62HM95 62" HDTV Logo
A
Anonymous Posted on Jun 29, 2014
How to change color wheel motor only - Toshiba 62HM95 62" HDTV
SljThere is a sound like a motor
Ur tv have a colors wheel design into it.The tv colors wheel it is defective and it is worn out,it is not spinning inside it motor mount axis motor baring anymore.The tv colors wheel is it defective that where the motor noises came from.The tv colors wheel it have to be replace to solve this making motor noises problems.The tv colors wheel it is sit way back of the tv.If u don't have any mechanical skills like take many mechanical parts aparts and putting it back together again.Don't atemp to change the tv colors wheel ur self.Hire a tv tech. to change the tv colors wheel.
The pictur freezes to balck and white.
Tv have a colors wheel design into it.Tv make alots of noises like grinding,humming,buzzing or pictures freezes or lost colors or flashes black&white flashes within the pictures.The tv colors wheel it is dying and the colors disc is it warping and not spinning correctly inside it motor walls axis anymore.The tv colors wheel must be replaced.The tv colors wheel sit way back of the tv and have to take out alot mechanical parts out before even can come to it and change it.If u have no mechanical skills.Don't attemp change the tv colors wheel by ur self.Hire a tv tech.person to change it.
I have a Samsung HLN617w that has an awful buzzing noise that seems to be continuous and maybe from the lamp fan. Any suggestions on a fix?
This tv have a colors wheel is dying and worn out.The sound u hear buzzing,squiling or lound motor noises.The colors wheel require changing,because it dying and spinning off of it motor axis.Hire a tv Tech. to change the colors wheel,because it sit way inside near the Light Projection Engine it self,require take out many machanical parts even can come to the colors wheel itself to change it.
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
3answers
High frequency noise
Hi. The most common cause for this is the color wheel. Replacing it requires removal of the engine/optical block. I'm not sure of your level of expertise but if you want to give it a try go to this website: http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ It'll give you some idea of what you're up against. It is similar to what you'll have to do but I don't think your chassis is exactly the same as this one so some things will look different inside.
Black and wight picture
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
2helpful
Color is horrible basically black and white
Ur tv colors wheel is dead,colors wheel is the problems,must be change.When the tv picture are black&white,colors fade in & out,loud squiling and motor noises.All these problems,indicate the colors wheel it dead,require changing.Hire a tv tech.for this job,because the colors wheel replacement require to take out alots of machanical's parts even able to get to the colors wheel to replace it.
1helpful
2answers
I have a Sharp 56DR650 Rear Pro. TV. w/ a LOUD color wheel motor
If the color wheel is making noise then its best to replace it and not try to repair it, Unfortunatley the wheel is not available by itself and a complete optic block part # 9NK3797086200...Be careful when taking the bock apart as it runs $900.00
1helpful
Changes colors
This is a DLP projection. may be that you have a defective color wheel motor or supply voltage to color wheel motor is out of range.
[email protected]
25helpful
8answers
50" RCA DLP color wheel replacement procedure
Mine started to howl last year, I sprayed out the motor using carb cleaner / lubricant. Its been running fine for over a year since.
My guess is, the bushing gets plugged with dust particals. If you catch it as soon as it starts to squeek, the carb cleaner trick may work for you too.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
