You asked about the USB connection between your camera and the computer. First, be sure you are using an approved USB cord that came with your camera. Nikon gets a little finicky if you use an off brand. Next, be sure your USB outlet is working on your computer. Plug something else into it to be sure it's functional. Next, reboot your computer and shut off your camera. After reboot turn your camera on to see if the computer now recognizes your camera.
It would help to know what software you're using for the post processing. Some software has an option to disallow uploading of duplicate photos. This could be the case if you've already uploaded these same images previously. You might want to check for that.
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
SOURCE: Nikon D40
Hey climiocid,
If what you mean is your images don't display on the LCD screen after you take the picture your image review option has most likely been turned off. If your camera just never displays any images I would try doing a hard reset on the camera by shutting off the camera and opening the connecter cover and pressing the reset button which should reset the camera to factory specifications. When resetting the camera this way remember this resets the cameras' clock. If none of this works I would have the camera looked at by an authorized service technician. You can find an authorized service center by contacting the manufacturer, or you can always bring your camera to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: d40 software
No drivers needed for Vista either. But make sure that you use the USB cable included with the Nikon D40x. My Cannon cable (although it looks identical, produces a Device not recognized error) with the D40x. The Nikon cable works fine, of course... I now have them marked.
SOURCE: problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
