Question about Elna Quilter's Dream 6003Q
Do I need to oil an Elna 6003Q sewing machine?
    Novelist:
    Habit-Forming:
  • Elna Expert
  • 116 Answers
Yes, in the middle of the bobbin case there may be a little hole with a wick below it where a drop of oil can be placed. Much of the internals are now self lubricating or designed for the tech to libe during the recommended annual service
Posted on Nov 26, 2014
5 Suggested Answers
6ya staff
SOURCE:
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
paj42
  • 1116 Answers
SOURCE: should I oil my Elna 3005 sewing machine?
Many of the new models do not require oiling.
Check the maintenace section of the manual for cleaning the shuttle area. Sometimes lint can build up and cause the machine to get noisy.
If it has been over a year since the machine was serviced, it may be time for a proffesional tune-up.
Posted on Mar 13, 2010
SOURCE: I have an Elna 6003Q
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Posted on Sep 27, 2010
SOURCE: change bulb elna 6003q
removed plastic plug (with a small screw driver,so the plastic plug
does not get damaged) on the side of the face plate
carefully removed screw behind plug--be sure not to strip the screw head
carefully pull or wiggle loose plastic cover until it comes off
giving access to bulb.
Posted on Jun 06, 2012
Where is the back stitch button on a elna 6003
If you have the owner's manual, it is supposedly called a "Reverse Key."
Elna United States Sewing Elna 6003
Look for a button near the needle with an arrow pointing backward.
Sep 18, 2016 | Elna Quilter's Dream 6003Q
How does one change the bulb on an elna 6003 sewing machine
Hopefully you have a manual that shows how to replace the bulb. Online Elna manuals have a fee.
Perhaps something here will help:
Change bulb elna 6003q
How do you change light on elna 6003 sewing machine
Watch Me For Minute Elna Lightbult Change
Jun 06, 2016 | Elna Sewing Machines
Lena sewing machine 6003 how old?
Hi, I'm Julie. Is the model of your Elna machine called Lena? Is your machine an Elna 6003? Is your machine an Elna 6003Q?
May 01, 2015 | Elna Sewing Machines
Jun 03, 2012 | Elna Quilter's Dream 6003Q
I have moved house and lost my manual for my Elna 6600 Quilting Machine - Can I get a new manual or perhaps a copy until I find my own manual. thank you Jules
Well you may please follow the link below to get your manual -
http://www.sewingnz.com/products/Elna-6600-Sewing-machine-instruction-manual.html
Good Luck!!
Thanks for using FixYa!!
May 02, 2011 | Elna Quilter's Dream 6003Q
Sewing Machines Logo
394 people viewed this question
Top Elna Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
Douglas Plant
Douglas Plant
Elation Relation
Level 1 Expert
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
