Question about Lenovo IdeaPad Yoga 13
When I plug in an external mouse, it won't click.
When I plug in a mouse to use (not the touchpad mouse, an actual external mouse), the computer won't recognize when I "click". The mouse will move the cursor on the screen, but whenever I try to select something, it won't work. Then, when I unplug the mouse, the touchpad won't select anything either.
    Champion:
  • 207 Answers
If an external mouse does not work correctly, you may need to install device drivers for it. Windows does not support all 'mice' just by plugging them in. Download and install the drivers for the mouse from the manufacturers web site. Do NOT do a factory recovery for a device driver problem.
Posted on May 13, 2015
6ya staff
SOURCE:
John Cunningham
  • 6771 Answers
SOURCE: Left click does not work. Both on touchpad and external mouse.
This indicates a virus in your system, since you can't use the mouse, I would do a full recovery to factory setting if possible.
Posted on May 11, 2012
allanhunt
Allan Bernales
  • 135 Answers
SOURCE: mouse touchpad does not respond but external mouse
Press Fn+F6 to enable touch pad but if it still doesnt work you may download the latest drivers for the touch pad on this link:
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_884.html
Posted on Apr 03, 2010
KIRAN KAUSHIK
  • 366 Answers
SOURCE: Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
Posted on Jul 01, 2010
Brian Murphy
SOURCE: cursor(pointer) cannot be moved by using touchpad but possibe wit
To stop the mouse jumping around whilst you are typing, have you tried configuring the touchpad? I had the same probelm but found configuring the touchpad to "disable whilst typing" then settng the "reactivation time" to one second.. This seemed to solve the problem in my case. I have a Medion Akoya. Good luck, Brian
Posted on Jun 07, 2012
TimeDefensiv
Shahzad Waseem Akbar
  • 746 Answers
SOURCE: thinkpad t510 4314 touchpad and mouse stop responding
It shows the fault of USB ports and in my point of view you need to replace with a new motherboard.
Hope it will be helpful.
Good Luck
Posted on Aug 22, 2012
I have a uniden wireless mouse and it won't
here ur pc is recognizing ur external hardware that is mouse but cursor is not moving this indicates that bluetooth connection is good and problem comes with the mouse. i advise to meet a good technician and there is nothing to do with it further.
Jun 28, 2013 | Computers & Internet
My Advent 5421 Touchpad Is Not Working!!!
Advent laptop computers are equipped with a touchpad and two buttons that service the function of an external mouse. The touchpad can be turned on or deactivated, depending on the user's preference. It's not difficult to either activate or deactivate it.
Power up the computer. Connect a plug-and-play computer mouse to a free USB port on the laptop. The mouse is just temporary to help you get the touchpad working again. Locate the touchpad icon, which is in the lower right-hand side of the screen. The icon will appear as a gray square or rectangle, with two rectangular buttons underneath. Use the mouse to double-click on the touchpad icon, opening a window on your laptop screen. Inside the touchpad window, click the option labeled "Enable Device". Select other options for the touchpad, such as pointer speed and shape. Click "Apply", then "OK". Disconnect the mouse from the laptop.
Feb 02, 2013 | Advent Computers & Internet
I'm using a Toshiba Satellite L655. Whenever I
open control panel
mouse icon
check settings
if all ok there then it might be that mouse drivers kaput reload from website or disc
May 24, 2012 | Toshiba Computers & Internet
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
May 26, 2011 | Dell Inspiron 1525 Laptop
My cursor does not move with the touchpad, only with the external mouse.
Not sure what OS you have, so I'm giving generic advice here:
under computer management or hardware, launch your Device Manager.
Scroll down the device manager to "mice and pointing devices".
Click the "+" to expand the list.
Find your touchpad on the list and right click it.
Select properties.
In the window, look for a way to enable the device.
Click OK.
It should work.
Dec 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
I think I clicked on the button that says Lock this Computer. and now my mouse is not moving. How do i fix this problem?
Firstly, Try a hard restart (Just hold down the power button until it shuts off)
If you mouse is still not working, you will have to use a external USB Mouse.
After a while, when this happend to me and I had used the USB mouse for about a week, the touchpad mouse started working again.
But, while you have the USB mouse plugged in, try searching online for a driver for your touchpad.
www.acer.co.uk
Hope I helped
Oct 31, 2010 | Acer Aspire 7720-6155 Notebook
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Touchpad will not work
Hello, seems like a problem with the touchpad, first disable and enable the touchpad with the button which is located at the top of the touchpad, the corresponding LED should change from blue to orange and vice versa. If this doesn't solve the issue, reinstall the driver for the touchpad, you can find this by searching for 'recovery manager' in the start bar. Next step is to select 'advance options' and choose reïnstall hardware driver, there should be an option called 'Synaptics touchpad driver' select and install. kr Gijs
Sep 10, 2009 | Compaq Presario CQ60-220US PC Laptop
Can move the mouse but not clikc with the touchpad
if you installed an external mouse, it would over-ride the touchpad.
try removing the external mouse, and tap the touchpad twice as if you were double clicking it.
also you could try re-installing the touchpad device driver, usually synoptics or similar.
Mike @ compurepair.
Jun 11, 2009 | Acer Aspire 5610-4648 Notebook
Mouse touchpad, keyboard, and usb drives will not work
One thing you can try (for the touchpad)
Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
Hope that helps for your touchpad
May 05, 2008 | Acer Aspire 3000 Notebook
Lenovo IdeaPad Yoga 13 Logo
73 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
