Treadmill Doctor Sportcraft TX 400 Walking Belt Logo
T
Tris Bond Posted on Jun 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I get my treadmill to stop knocking? I know it's not the motor.
When the treadmill is running there is a knocking noise in the front of the treadmill. I took the cover off so I know it's not the motor. IDK what it is.
Alma chee
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on Feb 02, 2015
Alma chee
Expert
Level 2:
New Friend:
Answers
69
Questions
0
Helped
81805
Points
161
Michael Carroll
Level 3:
An expert that gotĀ 10 achievements.
Master:
  • Master 742 Answers
  • Posted on Jun 29, 2014
Michael Carroll
Master
Level 3:
Master:
Answers
742
Questions
Helped
171142
Points
1973
Check the motor belt, more than likely has a burnt spot in it and can cause a knocking
Urevo treadmill - knocking noise
A knocking noise coming from the rear roller of a Urevo treadmill can be caused by several issues. The following are some troubleshooting steps you can try:
  1. Check for loose bolts: Make sure that all bolts and screws that hold the frame and the roller in place are tight and secure.
  2. Check the belt tension: Ensure that the belt is tight enough. If the belt is too loose, it can cause knocking and other noise issues.
  3. Check the rollers: Make sure the rollers are not worn or damaged, as they support the weight of the belt and can affect the alignment of the belt.
  4. Check the deck: Make sure the deck is not damaged or worn, as this can cause noise issues as well.
If the noise persists after trying these steps, it's best to stop using the machine and seek assistance from the manufacturer or a professional repair technician. Using a machine that is making a knocking noise could potentially be dangerous and lead to further damage.
tip
How to troubleshoot a noisy treadmill
First verify if your are getting the noise with a user physically on the machine, without anyone on, or both.
Creaking or squeaking while running on the machine usually indicates an issue in your incline motor, deck frame, springs, and or pivot points.
A loud grumbling noise getting louder and louder while elevating speed, usually means you have a bad bearing.
Any knocking noise coming from a treadmill indicates bad bearings in your front roller, rear roller, or drive motor.
Isolate the bearings in the front and rear rollers from the drive motor bearings.
To test: Unplug the machine, remove the main shroud, remove drive belt from drive motor and front roller pulley.
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise from the two rollers you can loosen the belt and turn each roller individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your drive motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills pivot points. Incline motor bolt, shaft, deck screws, and or any pivot points on the bottom of your machine. Metal on metal pivot points are usually the culprit in most cases.
Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal on metal needs to be lubricated to minimize wear and tear of those areas.
Synthetic grease works best or any spray on lubrication works fine if you do not want to remove any bolts or hardware.
If you ever find yourself needing technical support, please do not hesitate to call us 888-713-2880 or visit us online at www.sportsmith.net
on Jul 13, 2015 • Exercise & Fitness
Making very loud whistle noise
Be sure to verify if you are getting the noise while you are physically on the machine or with no one on it
To test: Unplug machine, remove the main shroud, remove drive belt from drive motor and front roller pulley
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise out of the two rollers you must remove the rollers and turn each one individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your Drive Motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills *pivot points. Incline motor bolt, shaft, deck screws, and or any *pivot points on the bottom of your machine. Metal on metal *pivot points are usually the culprit in most cases.
*Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal to metal needs to be lubricated to minimize wear and tear of those areas.
If you have any other questions please do not hesitate to call us or visit us online
888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Nordictrack 3700 makes a knocking sound when I run on it
Hello.
Knocking noises more than likely come from the rear roller, there could be a small chance it's coming from the motor it's self though.
Have some walk on the machine and make the noise while you locate which end of the treadmills coming from.
If it is the rear roller the bearings will need to be replaced, this can be done by removing the rear roller and taking it down to any bearing shop and have them locate the bearing numbers. Ask them for advise on removing them as well.
If the noise is coming from the front of the treadmill then have a look at the fly wheel coming off the motor, locate grub screws and tighten.
GymWorld.net.au
Thumping from motor reebok treadmill
Seem like your front roller bearings are knocking. Remove the drive belt. Turn machine on. Replace roller if noise goes away with drive belt off.
1helpful
Knocking noise
see the video attached. However LUBE the rollers bearing front+back with wd-40
God bless you
Knocking noise when machine running
see the video and fix it. This happen because the lack of maintenance according to the schedule. God bless you
Knocking noise when the motor is running on the left side
meant the motor have being hit and u should fine a repair shop
Clickling noise when running on treadmill
raise the incline and look under where motor is and spray some silicone lubricant on all the piston like things.
Knocking noise
Unplug unit open motor shroud , then replug unit , start the unit up then place tip on to the a 6" length flat screw driver tip on the front roller shaft put your ear on the insulated end and you should be able locate the knocking noise also check the motor and rear roller you insert tip where th adjustment is made. I believe that the front foller is causing your problem. Go to iconfitness.com go to customer service then replacement parts you will find your M# and pricing
Top Treadmill Doctor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
