SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
SOURCE: Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
SOURCE: I have a Samsung VRT front load washer, it was
First is to empty the water out. This can be done by following my (complete) general guidance notes below for checking the drain motor lint tray/filter and the motor.
'nf' means NO FEED and what happened afterward indicates that the water feed control valve is malfunctioning, initially not opening for water to be fed but then sticking open.
So follow these notes, particularly those in capital letters, to find how to empty the washer, and to check the state of the filter which is needed on a regular basis anyway ;-0)
Next will be a call to a service engineer to sort out the suspect valve.Sorry ;-0(
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
