D-Link DI 514 Wireless Router (DI-514) Logo
A
Anonymous Posted on Jun 29, 2014
How to set up D-Link Wizard page - D-Link DI 514 Wireless Router (DI-514)
Jyothish nv
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 95 Answers
  • Posted on Oct 05, 2014
Jyothish nv
Expert
Level 2:
Cheetah:
Answers
95
Questions
0
Helped
28177
Points
189
Please see the Dlink setup wizard.
http://www.wikihow.com/Setup-D-Link-WBR-2310-Wireless-Router
I have a G804V dlink router.I am unable to connect to internet after running the wizard successfully. During the wizard i let every value to be default and I set it up to obtain IP address automatically....
It shows that you have physical connection to the DSLAM at your service provider but may not authenticating with the server.
set up the ADSL basic setting with the model name http://support.dlink.com/index.aspx or If you still cannot browse the Internet or not able to access the page. Follow D-link Router Support for share more details.
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
11helpful
Lost my setup cd for my D-Link Dir-601. where can I get the software?
Directly from D-link web site.You can use the wizard, but I have an checklist of must do items....
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
When i try to connect it will not get connection to internet. If i by pass the router it will connect
Hi rarebed, Your router needs to be set up D-link has an automatic setup wizard just connect you router to the computer and type 192.168.1 in the internet's address bar. hit enter and enter again on the next page (you don't need a password) then pick automatic setup and follow the wizard. http://www.fixya.com/support/r4219065-set_up_wireless_router_use_wireless For General manual instructions
Loses the connection
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
1helpful
2answers
Help me to resolve a problem with my Router
To access the configuration page of the Dlink router, use a wired computer or directly connect your laptop to the router using an ethernet cable. Then open any internet browser and in the address bar type: 192.168.0.1.
Select Admin from the drop-down arrow and then enter your password. Leave the password blank by default. If it doesn't work, then you will need to reset the router.
At the back of the router there is a reset button, hold it down for 30 seconds.
Then try again to access the router. Reconfigure the router's internet connection, depending on your ISP. Under Setup>Internet page, click the Internet connection Setup Wizard button to automatically configure the router.
Then for the wireless settings, go to Setup>Wireless Settings page, then click on the Wireless Network Setup Wizard to configure the wireless settings.
1helpful
How do i setup the scanning part?
hiii
You can perform following step:=====
1.Insert the document you want to scan into your scanner.
2.Click Start, click All Programs, click Accessories, and then click Scanner and Camera Wizard
3.The Scanner and Camera Wizard appears. Click Next.
4.In the Choose Scanning Preferences page, click the Picture type option that best matches the paper you are scanning, and then click Next
5.In the Picture Name and Destination page, type a name for your image, select JPG as the file format, and select the folder where you would like the scanned image to be saved. Click Next.
6.Windows XP scans your document. On the Other Options page, click Nothing. Then, click Next.
7.On the Completing the Scanner and Camera Wizard page, you can view your scanned document by clicking the link shown. If you are not satisfied with the results, click Back to return to the Choose Scanning Preferences page, adjust your settings, and try your scan again. Repeat until you are satisfied. Click Finish to close the wizard and open the folder containing your scanned document.
Don't have Driver, so I can't hear anything
Here is a link to the Intel support page for their onboard audio. It contains a link to their audio wizard as well as a link to their download page. I would suggest running the audio wizard first to properly identify your hardware and the type of driver necessary.
If this doesn't resolve your issue please post under this thread so I can provide more assistance.
2helpful
2answers
Cant access set up wizard for d-link DI-524UP wireless router
Here is a link to the D-Link's site based wizard:
http://support.dlink.com/emulators/di524/h_wizard.html
No access to set up wizard
what is the model of the Wireless acces point. Check is there any reset button. If so, press it for 10sec. and try the same
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
