SOURCE: kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
SOURCE: KitchenAid 5 burner Cooktop conversion to LP gas
you need orifices for lp and the regulator should be convertable there is a "plug" thing in the middle of it that you remove and turn over and install
SOURCE: replace dcs gas cooktop re-ignition module
donho1,
most likely the problem is the switch places onto the shaft of the valve. to replace the switch, you would need to remove the burner cap and port rings. you will see a large brass nut that needs to be removed on all 4 or 5 burners. next you would need to remove the nut in the center of the simmer port ring which is also the venturi for the main burner. you must be careful when removing this nut as they have a tendancy to lock onto the jet holder and could be hard to remove (don't strip or break the venturi or holder).....after you remove those nuts, the burners and top can be removed (watch the igniter wires). you can remove the switch by removing the retainer clip that holds the switch onto the valvestem.
SOURCE: Need LP conversion kit for kitchenaid cooktop kgcp483kss
Hiya there,
Now I have not read this manual because I would really need to physically see and inspect the make and model of cooker that you have in order to advise you on this exactly, but even so here is a manual I have found for you to read. If however this does not turn out to be the right one for you, please let me know and I will find you the correct manual ASAP.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kgcp483kss.html
I hope this is the fixya for you, and if you haave any problems, questions or comments please get in touch and I will respond accordingly.
Yours sincerely
Oz
SOURCE: Kitchenaid gas cooktop igniter turned on by itself
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
