Rangemaster Toledo 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
B
Bob Davis Posted on Jun 28, 2014
Rangemaster Toledo noisy fan issue - Rangemaster Toledo 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
5 Related Answers
Anonymous
  • 99 Answers
  • Posted on Oct 23, 2008
SOURCE: Door handles on rangemaster toledo 110 duel fuel
Yes this is easy to do.We can supply bits if required.
FitzOriginal
Chris Hall
  • 842 Answers
  • Posted on Jan 23, 2009
SOURCE: Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Anonymous
  • Posted on May 31, 2009
SOURCE: warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
Anonymous
SOURCE: rangemaster toledo 110
Hold down two left hand buttons together for a long time. that should do it.
Ross Clifton
  • 136 Answers
  • Posted on Oct 25, 2009
SOURCE: Rangemaster Toledo 30 - The glass in the oven door
junk it and get a new one !!!!
How do I replace a ceramic top to my rangemaster Toledo 90 cooker
This job is for qualified person. Is not recomadet to doit yourself.
1helpful
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
3helpful
Rangemaster toledo 110
Toledo 90 side oven fan not working.
We had the same problem about 2 months after we bought the cooker. The engineer had to change the fan motor.
Fan belt fitting seat toledo
After removing the cover, it should be obvious that one of the pulley's has an adjustment (could be the motor that drives the fan itself) to allow removal and refitting the belt, otherwise there will be a tensioner pulley that has to be released to remove and replace the belt.
14helpful
3answers
Oven fan noisy/broken
this noise probably means that the fan is about to stop working, this is what happened to mine. You can easily buy replacement fan off E-bay (it seems easier to find the right fan on e-bay that any of the confusing supplier sites). You then just need to remove the inside oven back and the outside electrical to replace the fan.
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
