Not closing properly. tends to hang low. A little lift and it is sealed properly. How do I re-align the freezer door
SOURCE: I have NEW sumsung ref. 25.5 french door with freezer at bottom
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
SOURCE: My Samsung French Door RF266ABPN has a warm
I have read that if you unplug the unit and plug it back in again, it will "reset" it. I would wait 15 or so minutes before replugging just to be sure. Of course, this solution doesn't preclude the problem from happening again - sounds like a manufacturing defect to me.
SOURCE: I'm getting frost in freezer of my Samsung french
i would check the magnetic seal around the door to make sure it is not letting air in ...this is the cause of the over freezing.
SOURCE: Samsung refrigerator Not cooling below 45 degrees
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dffg
SOURCE: RF263 series Samsung Refrigerator just began
Hi The sound comes when there is ice build up around the fan
and the fan will hit it causing this sound. You can try to leave it unplugged
for around 4-24hrs and also make sure that the area near the back is clear so
that airflow can get through. If the issue returns then replace the thermostat.
Hope this helps...please post back for further assistance. Daniel
