Hi Karl,
Can you use the unit after the symbol goes away?
The operating manual may be downloaded at;
http://safemanuals.com/annexe_INSTRUCTION%20MANUAL_SAMSUNG_HT-Q100T%20-%20HT-Q100-_E.htm#
The closest symbol to the one you mentioned is listed at page 28 of the manual. It is the "elapsed playing timer" symbol. This function is controlled by the "Remain" button.
Page 10 of the manual has a similar looking symbol warning you not to use certain incompatible disc formats;
Do not use the following types of disc!
• LD, CD-G, CD-I, CD-ROM and DVD-ROM discs cannot be played on this player.
If such discs are played, a "
WRONG DISC FORMAT" message appears on the TV screen.
• DVD discs purchased abroad may not play on this player.
WRONG REGION CODE" message appears on the TV screen.
Page 54 of the manual lists a reset procedure in case the unit power trips off or behaves errantly;
• Turn off the power and hold the button on the main unit for
longer than 5 seconds.
Using the RESET function will erase all stored settings.
Do not use this unless necessary.
Jango.
its the little fan in the front of the sytstem i just opened mine cleaned it off it was caked with dirt preventing it from spinning once i cleaned came right back on if yours still doesnt work after cleaning just replace it and it should work again
it even ran quieter after
