Band or bracelet? If a band/strap it should have a buckle just like a belt. If its a bracelet it will have a clip down catch bor it will have a push button release.
Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
Depending on what brand you are seeking, I stock a great many. The Rolex oyster bracelet being very popular and one of my best sellers. I can supply bracelets for any watch. If the factory made it, I can get it. Email me [email protected] Have added some pics of the Rolex bracelets
Step 1
Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
Step 2
Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
Step 3
Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
Step 4
Remove the link from its neighbor and replace one pin to secure the bracelet.
Making the Band Longer
Step 1
Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
Step 2
Push the pin out so the link is detached from the clasp.
Step 3
Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
Step 4
Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
Step 5
Repeat this process if you need to attach more than one link.
mcdevito75 here, Many watches built today are not comming out with replacement Bands (straps, Bracelets) from the factory, the cost of makeing and keeping extra bands on hand is too high, they should at least have a few extra links to replace worn ones. Chances are your warantee is over on the watch and in that case, you"ll have to find another band, Bracelet on your own. Best Bet, visit a small watch repair shop in your area for another bracelet, band, Strap.
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
